I use S32K144 EVB, S32DS for ARM and SDK EAR 0.8.6.
I want to use PTB17 as SPI Chip select PIN.
But It does not work.
Can I use PTB17?
If I can use PTB17, How to use PTB17 as chip select PIN?
Byungju.
Solved! Go to Solution.
Did you select the following?
Dear Danial,
Thanks for your help.
Byungju.
