TJA1145 SPI communication failure
空心木头_mm
Hello :
      I am using the can transceiver TJA1145T,and I can not get the right response when I send a 0xfd to it,I am sure I have the right connection among the pins,when I monitored the SDO pin of the TJA1145T,  I found it copy the information I send to it from the pin SDI sometimes,why could this happen ?Can anyone help me?
best regrads!
TomasVaverka
Hello Mengmeng,
Do you have an oscilloscope to check if the timing and format of the SPI message is correct?
A very common problem is that timing parameters are violated, so please make sure everything is in accordance with the following specs:
Tomas
1971439734
I have check the format, but i still can't read back the device id, any other solutions? please
syfchao
hello:
     I have the same problem? do you solve it ?
