SDK_2.3.0_MKE06Z128xxx4: fsl_gpio.c
for input setting, set PDDR OK, not set PIDR, still disable IO input, read IO return 0.
set PDDR and PIDR for input IO
Thank you for the info.
The latest MCUXpresso SDK for KE06 had fixed this issue.
Please check below GPIO_PinInit() function at <fsl_gpio.c> file:
Mike
Thank you !
Thank you !
