MODEL BASED DESIGN TOOLBOX [Registration Code, S32K144]
electronica2pow
Hello to the community,
I am owner of a S32K144 platform and i would like to download the "Model Based Design Toolbox", but when i click on the link appears a message: "There is currently no Software or Support in your account. To register a new product, enter the registrion code below." Where could i find the "Registration code" in order to download that model?
I was entering codes from the NXP package, but none of them works.
Jorge
dumitru-daniel_
Hi Jorge,
Please go to this link: Model-Based Design Toolbox|NXP
Select Download
If you are logged in with a valid NXP account then you should see this page:
Can you confirm this ?
Perhaps the link you are trying to download is broken or the re-direct might not temporary working.
Hope this helps!
electronica2pow
It was really helpful and you solved my problem Daniel.
But i want to tell you that your coworkers should give a look to the Reference Manual of the Toolbox: https://www.nxp.com/docs/en/reference-manual/MBDT-User-Manual-for-S32K.pdf
Pictures don't appear, so maybe there is an issue there.
Jorge
dumitru-daniel_
Hi Jorge,
Thank you for reporting the issue. Please use this one attached. I'll inform our web admin. Anyhow, please be aware that starting with v3.0.0 we have replaced the PDF documentation with MATLAB Help.
