Reset safe scratch registers
andreweipel
Hi ,
I would like to implement a boot counter in u-boot, therefore I would need some register where i can keep the boot counter value. This value shall not be reseted after a HW reset.
Usecase: System cold boots, bootcounter increased by one, try to boot Linux, successful reset this counter.
If Linux panics on boot up, watchdog interrupts, u-boot boots again bootcounter ++;
If countervalue is e.g. > 4 then load alternative Linux.
Are there any registers on the vf6 cpu that are "reset save" and could be used for this usecase?
Thanx a lot, Andi
Carlos_Musich
Hi Andreas,
The low-power (battery-backed) section incorporates a secure real time counter, a monotonic counter, and a general-purpose register. This portion of the block is powered by a battery that maintains the state of the SNVS_LP registers when the chip is powered off.
Please take a look to Chapter 7SNVS, Reset, eFuse, and Boot of Reference Manual.
https://www.nxp.com/docs/en/reference-manual/VFXXXRM.pdf
Carlos
NXP Technical Support
