CAN bus connection for 4-different-GND boards
aaronlee
Contributor V
I have a new project. I want to using S12ZVCA on each board. These board have different GND. May I using CANPHY on this project?
Aaron
danielmartynek
Hi Aaron,
I’m afraid this will not work, the CANH/CANL needs a common ground between the nodes.
You can use a galvanically isolated CAN transceiver, such as TJA1052i.
danielmartynek
Hi Aaron,
aaronlee
Contributor V
Dear Daniel,
Thank you very much.
Aaron
