Part of the MPC5746R PASS encryption
tianyuliu
How do I write four sets of passwords to DCF records? In what way?Thank you.
petervlna
You have these options:
1. use debugger (or debugger script)  to write DCF records into UTEST flash block.
2. use SW flash driver to write to DCF records in UTEST flash area.
Peter
tianyuliu
I've solved the problem, but thank you all the same.
tianyuliu
Who can help me?  Many thanks!
