MC33907NAE different mask set
ziomocci
Hi all,
 We have two prototypes with same SBC MC33907NAE but different mask set.
One with an MC33907NAE-CTAQ1609H and the second with MC33907NAE-CTAM1551K.
I have not found any document or specification with difference between them well defined.
The question is automatic: which are the difference? Voltage reference, reset lines, power supply, etc etc.
And, not less important, could I use same sw driver APIs
https://www.nxp.com/docs/en/user-guide/KTMPC5643DBDEMOUG.pdf?fsrch=1&sr=3&pageNum=1
with both devices?
Thank you in advance.
Andrea Mocci
Tags (3)
davidtosenovjan
It should not be any difference, it is only different date code (YYWW = date code)
