Can MfgTool use USB 3.0 port?
zhaomanhong
Hi all, i have a issue about MfgTool (not MfgTool2),
The detail is that the MfgTool only connect USB 2.0 poart inside PC, it is well.
But connect to PC's USB 3.0 port, MfgTool will not be able to see the device.
My MfgTool ver is V1.6.2.050-gd07d0fa.
Thanks a lot.
Rita_Wang
Which board are you using?
Rita_Wang
By now the usb3.0 is not support on mfgtool. Here you can try to use the usb-hub to PC.
