OL2385 low RF Output power issue
rakshitbhatt
We are using OL2385 transceiver module.
We are getting "6 dB" less power than configured.
So to debug I have following questions.
  • What is the  complex impedance that chip should see when it is in transmit mode?
  • I am measuring output impedance at antenna port, but issue is that,  measured impedance is same when chip is power off or Powerd on!
    • What should be the configuration of Chip to measure transmit impedance?
Thanks With Regards,
Rakshit Bhatt
estephania_mart
For a better support could you please submit a case in Support|NXP  ?
Estephania
