Hello again,
Thank you very much Ware. I have some questions.
Is it possible that if I do not wire VADD to GND through bypass capacitor, my transceiver does not transmit far away? Because the others pins are connected like you do.
How far have you been able to separate each other and to receive information?
The pins 13 and 14 are GND and are I/O, so if you make in number 15 GND the others have GND as well. But, do you think it is gonna be better if you wire 13 and 14 to GND directly?
Thanks a lots and my best regards.
Jose
Message Edited by josehida on
2008-10-02 11:03 AM
