Hi, team, I want i.MX6 output RGB666 format via parallel DISP0_DAT0-23 ports, and my display interface has only 18 input pins, which ports should I choose? DISP0_DAT0-DISP0_DAT17 or can be configured by registers?
Thank you very much!
Solved! Go to Solution.
In 18 bit mode the pin mapping should be the following:
DISP0_DAT0:DISP0_DAT5 - B0-B5
DISP0_DAT6:DISP0_DAT11 - G0-G5
DISP0_DAT12:DISP0_DAT17 - R0-R5
Victor
Victor
Hi, Victor, thanks for your reply, can you tell me where I can find the corresponding configure info?
