I am checking update information with latest IMX6DQ6SDLHDG.pdf (rev 2.0).
However, I could not find following changes into rev 2.0 document.
Could you point out about changed contents?
<Changed information from Appendix A Revision History>
- Added new row 5 to Table 2-1 (old row 5 now row 6).
- Added new row 7 to Table 2-1.
- Updated Length - Min values for Byte Group 1?8 in Table 3-3.
Kazuma Sasaki.
Solved! Go to Solution.
Hello Kazuma Sasaki,
I was reviewing both revision 1 and 2 and couldn’t locate these differences. These values you listed are the same in both Rev 1 and Rev 2. It does look like it was an error on the change log.
Do you have both versions of the document?
Hello gusarambula,
Yes, I have both versions of the document. and, checked both versions.
Anyway, I will follow the latest document.
Thank you so much for your support.
Kazuma Sasaki.
Does anyone have any information about this topics? Is it typo?
Kazuma Sasaki.
