S32 FTM
S32 FTM
wangfei11
I use the S32 register routine, but it will be connected, or I can't see the PWM signal. Please modify the program so that it can output the PWM waveform.
stanish
there is a SDK FTM example for S32K EVB available. You can use it as a reference:
S.
