"PinSettings" component settings in Processor Expert(PE)
sreenivasuluvak
In most of the S32 SDK  Demo  projects ( for example lptmr_periodic_interrupt_s32k144 and power_mode_switch_s32k144)  all unused Pins have their  "Pin Mux" set to "Pin disabled (analog)".      Is this the recommended setting for all unused Pins in a real application as well?    If not, could you please suggest the recommended settings for unused pins in the  "Pin Settings" component in order to achieve lowest possible  power consumption both in RUN and STOP modes.
martin_kovar
please check the thread below:
https://community.nxp.com/message/936264
Martin
