hi all
i have a problem in debug mc9s12dg256c using P&E USB Multilink BDM. in program, i did nothing initialization to mc9s12dg256c system clock (all register value are reset values) and interrupt is diabled (//EnableInterrupts
, after i download the program to the target, it can run correctly using BDM, but when not using bdm, the program can not run.
thanks for help!
