SATA interface design
daramsreedevi
I need to design a board with ethernet,SATA,USB interfaces.which one i should go CortexM4 or processor model.This will be used for data storage.
jeremyzhou
Hi daram sreedevi,
for the opportunity to serve you.
There are none of NXP Cortex-M core MCU integrates the SART controller, however the PowerQUICC Processors are able to do.
Hope this helps.
TIC
