Dear all,
I refer to the "Figure 18-2. Clock Tree - Part 1" of Reference Manual.
ACLK_CLK_ROOT is listed, but I was not able to find the module which used this clock with a reference manual.
Is this clock used in i.MX6Solo?
If this is not used, can I leave the related register the default?
Yuuki
mx6solo use this clock, one can set it through CCM_CSCMR1 register.
detailed information, one can refer to the Figure 18-8. of Reference Manual.
Dear Joan Xie-san,
Thank you for an answer.
However, I cannot find a peripheral using ACLK_CLK_ROOT.
Which peripheral is ACLK_CLK_ROOT used for?
Yuuki
