Problem with S32 Design Studio for Power v1.2 - Update 2
jobu
I get some error messages if I try to install the update. Please see attached file.
Some hints to fix the problem are welcome...
Jörg
jobu
... I finally manged the update. I have disabled all URLs in "Available Software Sites" and then it works.
Jörg
jobu
Jörg
jobu
... I have switched off the firewall but no difference. Also my network connection is fine.
Other suggestions?
Jörg
jiri_kral
Hello Jörg,
I updated S32DS right now and have no issue with that. In your case it may be some temporary network outage or firewall issue on your network. If the errors are still present - check the firewall settings and network connection.
Jiri
