Kinetis Expert support for MKW30Z160?
giovanni
We are using the MK30Z160 with Bluetooth in our design.  I really love the utility of the Clock tool in Kinetis Expert.  Any plans to support that core?  If no, can I utilize a core that is similar to generate clock initialization code?
estephania_mart
The information Jing Pan works fine if the MCU you are using is the MK30DX128, but if you are using the MKW30Z160VHM4 you can use the MKW31Z.
Estephania
jingpan
Hi Gary,
You can download MK30DX128 or other MK30 serial SDK package. Since they all belone toMK30 family, their clock tree struct are same. So you can use any config tool to generate clock config files.
