When I try to program the NOR Flash using the U-Boot binaries, I get Sector Protection Error. Can you please advice what is wrong.
Original Attachment has been moved to: T4160_FlashProg_log.txt.zip
Test your configuration on the T4080RDB board.
Check Flash programmer setting for your Flash.
Look at the AppNote-FlashProgrammer-PowerArchitecture.pdf file, This file is available in CodeWarrior folder using the following path:
C:\Freescale\CW_PA_v10.5.1\PA\PA_Tools\FlashToolKit\Documentation
This file also is available in the attachment.
Use this file to add new Flash in CodeWarrior Flash Programmer.
Pavel Chubakov
