I use codewarrior with the KIER121 and the kit microcontroller MC68HC908GP32. I use class 3 and mon 08 interface. I made a simple programm to light the leds. Then I have: Attempting soft reset of HC08 device... Success. ( RSR=$48) Initializing. Target has been RESET and is active. CMD>CM C:\Program Files\Freescale\CodeWarrior for HC08 V5.1\prog\P&E\908_GP32..... Initializing. (Bus Freq = 2466Khz) Initialized. ...... Loading programming algorithm.... Error writing data block to part. Disabling block write. Try again. Error 14 during script !
If somebody could help me on that error 14, thanks
