Hello everyone,
i am trying to program the TJA1100 PHY for BroadR-Reach Automotiv Ethernet with a STM32F407 µC. The PHY does not send anything over the twisted pair cable.
I read the value of the PHY registers:
Basic control register: 0x2100
Basic status register: 0x1E1
PHY identifier register1: 0x180
PHY identifier register2: 0xDC48
Extended status register: 0x80
Extended control register: 0x9802
Configuration register1: 0x5A11
Configuration register2: 0x2245
Symbol error conter register2: 0x00
Interrupt status register: 0x00
Interrupt enable register: 0x8000
Communication status register: 0x6004
General status register: 0xC000
External status register: 0x00
Link fail counter register: 0x00
Are the settings correct?
What changes should i do?
Thank you in advance.
Hi Rami
unfortunately I am not aware of tja1100 driver, but one can check datasheet and common steps
http://cache.nxp.com/documents/data_sheet/TJA1100.pdf
TJA1100 in imx6 with Managed mode
