Hi all
I am useing the platform of imx6qp which is base of android7.1.1 os .Now execut the cmd "mount -o remount,rw /system" ,but the result is "mount: '/dev/block/mmcblk3p5'->'/system': Device or resource busy".
Please teach me how to have done it. Thanks!
Hi All,
We are also facing the same issue. Can any one got succeeded please provide the answer for the issue.
Anji
Please connect your platform to your machine via USB cable and use the following ADB command:
$ adb remount
Gary
Thank for your answer! I have executed the cmd " adb remount" ,but the result is the same .It have no work.
It is most likely due to SELinux enforcing that remount. Can you add the following arguments to the bootargs:
androidboot.selinux=permissive
Gary
