Hi ,
I am working on IMXsolo based target board and in my design Serial (SPI) NOR flash is interfaced with the IMX6. NOR flash is supposed to be having the uboot . I want to know , how to program the uboot over the NOR Flash. Do I need external SPI programmer or there is any other option in IMX6 using which I can flash the uboot over NOR Flash. Please suggest.
Hello Aditya,
As you already mention in a different thread, you can download the code of your media using MFG Tool, How to use MFG tool to flash Uboot and Kernel on NOR Flash . But you can flash the media in other ways like you are mention can be done with an external programmer which I think it is a best option for production in a fastest way. But for development the MFG Tool, it is a good option.
Jaime
Hi Jaime ,
Thank you for you reply. Just want to understand , if I go with the external programmer , what are the addresses at which U-boot and Kernel and rootfs need to be flashed ?
Aditya Nagal
