Question about NTAG I2C plus Flex Antenna Class6.
gxu
We are doing a project with your NFC chip NT3H2111. In this project, NTAG I2C plus Flex Antenna Class6 was adopted.  We want to design a new PCB which includes this antenna Class 6, but we could only download a Gerber document about it . Could you please send us a PCB document about NTAG I2C plus Flex Antenna Class6?
Tags (2)
Kan_Li
Actually the PCB document come along with the Gerber document, you may fetch it from http://www.nxp.com/documents/software/SW3646.zip. Anyway, I attached it here for your convenience and you should use EAGLE to open that file.
Hope that helps,
Kan
VilemZ
Hello Kan,
I prefer 1 too, but I still haven't got layout for antenna for Eagle. I cannot import any file, which you recommended me.
Thank you.
Vilem
Kan_Li
Hope that helps,
Kan
VilemZ
these files really helped me too. But now, I want try PN7120 or PN7150, but I cannot find something like that for Eagle software. Please, could you help me? Have you got any similar files for PN7120 or PN7150?
Thank you very much!
Vilem
Kan_Li
Hello Vilem,
Please refer to the following for details.
PN7120:
https://www.nxp.com/downloads/en/board-support-packages/HW3739.zip
https://www.nxp.com/downloads/en/board-support-packages/HW3346.zip
PN7150:
https://www.nxp.com/downloads/en/board-support-packages/HW3560.zip
https://www.nxp.com/downloads/en/board-support-packages/HW3561.zip
Hope that helps,
Kan
VilemZ
Hello Kan,
thank you very much for the fast reply and for the links. I tried use it in eagle, but I cannot import the BRD files. Maybe, it is not for Eagle. I need mainly antenna for my design.
And one additional question. Can I use external antenna - for example this: https://www.molex.com/molex/products/datasheet.jsp?part=active/1462360031_ANTENNAS.xml&channel=Produ...
Thank you.
Vilem
Kan_Li
Hello Vilem,
We have a NFC antenna dev kit available, NFC Antenna Development Kit | NXP , why not use this?
Kan
VilemZ
Hello Kan,
Thank you, it looks good for development. But I need something low-cost for small production, too.
I have two solutions:
1. PN7150 + own antenna on own PCB
2. PN7150 + cheap external antenna + own PCB for PN7150 only
Thank you.
Vilem
Kan_Li
Hello Vilem,
Actually I prefer 1.
Kan
gxu
[email protected]
