rpm_5.4.16.bb, do_compile build error
ahmetkoc
Hello everyone,
When i am trying to build compiler by using  Yocto DISTRO ?= 'fsl-imx-fb' but there is error as i mentioned on the question keeps popping in while the progress is still going on. Compilation can not be finished. how can i fix this issue? Configuration files and error message can be reach by the link below.
thank you in advance.
http://textuploader.com/d1j6c local config
http://textuploader.com/d1jja error message
Labels (3)
ahmetkoc
Thank you for your return.
I resolved this issue by switching to TLS from 15.04 to 16.04.
gusarambula
Hello Ahmet,
Are you still experiencing this issue? Are you using an Ubuntu 14.04 host and 4.1.15_2.0.0 BSP Release?
