Hi, we need access to an older NXP Code Signing Tool V 2.3.1 as the V2.3.2 does not work with the project source I am working with, is there a way to download an archived version of the tool?
Solved! Go to Solution.
Hi Jim,
this tool is only provided under NDA and the old versions are stored in local repositories, you may contact your FAE or DFAE to ask for the tool and sign the NDA.
Carlos
Hi Jim,
Carlos
