Error validating location: "Could not connect to : pserver:anonymous@dev.eclipse.org:/cvsroot/eclipse: I/O exception occurred: Connection refused cvs [pserver aborted]: /cvsroot/eclipse: no such repository"
Seems this repository is not available. You probably get this info from Eclipse help.
Anyway, before you connect to a repository please make sure it exists and you have a credentials.
if you intend to create a new CVS repository - you can try to Google it.
Hope it helps.
Stan
