hi ,would you please help to check if LS1043A contain pcm/Tdm highway transmit pcm audio data ? I have checked the Ls1043A datasheet in NXP website,It is not very clear about it . Thanks you
Yes, LS1043A device has TDM interface which supports PCM highway. This interface is a part of QE block.
Please refer to QE Reference Manual, Chapter 22 for more information.
