Regarding the TJA1020, is this a common LIN transceiver or is there a newer typ from NXP available ?
Hi Andreas,
The TJA1020 is an old device compatible with LIN 1.3 specification only. Newer devices support LIN 2.x and SAE J2602.
Please let me know if you have any other questions.
Tomas
PS: If this answer helps to solve your question, please mark it as "Correct". Thank you.
