The INT irq never goes Low of PCF8563 Real time clock. Even with Alarm with bit AF and AIE = 1 or Timer , bit TF and TIE = 1, I try everything voltage: 3.3v or 5v pull up resistor 2k; 10k ; 100k; 10M
Every thing works setting time, Alarm, Timer except INT .
Hello Jean,
Are you clearing the interrupt flags at the beginning of your application?
Can you share with me the schematic?
Please make sure the bits TIE and AIE are enabled, otherwise, pin INT will remain high-impedance.
David Diaz.
