Content originally posted in LPCWare by vostro1000 on Wed Jan 18 09:20:50 MST 2012
Quote: CodeRedSupport
Thank you for the project files. These now build fine.
However I don't see any problems loading the project intothe debugger. I have tried changing the value of the parameters being passed to the PWM() function between builds, as suggested in the caprock.c in the workspace that you sent.
Next step would probably be to provide more details of exactly how to replicate the problem, plus provide a copy of the debug log from when you get the load failure as previously requested - I gave a pointer to an FAQ on to how to obtain this.
Also, out of interest, if you import the projects that you sent in new.zip into a fresh workspace, can you still replicate the problem?
CodeRedSupport
Today I cannot replicate the problem... But as you can see from logs a lot of erros happens. It's a trick bug :cool:
