Content originally posted in LPCWare by micronpn on Tue May 11 10:30:41 MST 2010
Is there any trouble/problem to manually change the GCC compiler (i.e. changing the pointing directories of the IDE) and use a different GCC release then 4.3.3?
Or in alternative may be possible manually substitute GCC bins in lpcxpresso path?
