Content originally posted in LPCWare by Mega on Mon Jun 29 11:22:31 MST 2015
Im using nxpusblib 0.98 since lpcopen doesn't contain Massive Storage Device example.
I can read but cannot write.
The problem is this loop on EndpointStream_LPC.c
"#if defined(__LPC17XX__) || defined(__LPC177X_8X__)
if (endpointselected!=ENDPOINT_CONTROLEP)
while(usb_data_buffer_OUT_size == 0); /* Current Fix for LPC17xx, havent checked for others */
#endif
I tried to remove the code in red zone and starts to write. But it damages sectors 8192(with CSD info). If I eject the device at the next time I connect the device Windows asks to format.
Anyone got any idea?
Best Regards
