Content originally posted in LPCWare by chethan kumar on Wed Jul 30 00:12:35 MST 2014
Thanks for your reply....
I changed IDE version as per you are mentioned above in this version i couldn't work with lpc examples also (attached .rar file above). and i worked on LPCOPEN example freertos_blinky porject i didnt get any result. previous version IDE what i said everything is fine (if i work within the example project)only the problem is when i go to create ne project it wont work but in this version i didn't get the result with even examples also.
chethan kumar
