nxpUSBlib CDC class
nxpUSBlib CDC class
lpcware
Content originally posted in LPCWare by mshrestha789 on Thu May 22 02:06:53 MST 2014
Hello friends,
In errata sheet it is return "The CDC class USB ROM drivers return a STALL condition after the DATA stage of a Set Line Coding CONTROL transfer from the host". Is this still a problem in the provided driver or is it already fixed? Any help regarding this will be highly appreciated.
lpcware
Content originally posted in LPCWare by embd02161991 on Fri May 23 12:55:05 MST 2014
The bug exists only in Revision A parts as stated in the errata sheet. This has been fixed in Rev C parts.
NXP Technical Support
