Content originally posted in LPCWare by Rahul mankumbare on Fri Jan 15 06:25:52 MST 2016
I want to use LPC1768 as a master & other LPC1768 as a slave in SPI.
I am using code bundle eg
In first LPC 1768 I am using master program & in second I am using slave program.
But it gives verify error as a output.
As in example code of Slave clock is generated . Why it is required when master clock pin is given to slave clock pin.
