Dear engineer, I have a question about simulation of signal integrity of DDR3L.Enclosure is the result of my simulation(R-C parallel termin--ation is done), including the signal wave on driver(CPU side) and receiver(DDR3L side).It bothers me tha
longqiluo
Bulat
What is the question?
longqiluo
the problem has been solved but thank you as well! Now  I am using p1023 for my design,when I using CW10.5.1 to download u-boot to my board,I have problem.my board NORflash is S29GL512P, organized as  32 MX16 X1 ,  I just followed the applicqation note AN4948 to burn flash to my board, but I can't execute the step"Add flash programmer actions"because the button is invalid   and gray , could you tell me what happened and how can i download u-boot to my board?
addiyi
Did you use Linux OS?
longqiluo
yes ,but now I just take the step to programmer flash ,after last problem,I found something worry in my init file ,now I get new problem like below
my init file select like below:
do you have any suggestions for my problem?
addiyi
Do you use Usbtap or Cwtap? Also, check if you can manually launch ccs.exe from \PA\ccs\bin\.
Adrian
