MK20DX256VLH7 Power Up
nishantpashine
Kindly let me know how to power MK20DX256VLH7 microcontroller(how component and crystal I have to place around microcontroller)?.
Also, tell me whether I'm right if I am using SWD mode to burn the code via Ulink2 debugger through keil?.
jeremyzhou
After had a brief look through the statement, I've attached the Kinetis Peripheral Module Quick Reference which contains the code examples, useful tips and quick reference material, so it can help you out.
The Ulink2 can program the K20 through the SWD interface.
Ping
nishantpashine
Hi jeremyzhou,
Thanks for the reply but where is the attachment.
Kindly attach here.
jeremyzhou
Please check the attachment.
Ping
