HI Lpcware_Support,
My csutomer is using I.MX7D(CotexA7+M4) on their project, and they are running FreeRTOS on M4. they are planning to port emWin on FreeRTOS running with M4, and they are using
GCC revision 4.9-2015-q1-update from ARM Embedded
cross-compiler to compile FreeRTOS, is it possible to provide emWin lib which generated by GCC revision 4.9-2015-q1-update from ARM Embedded to customer? Pls comment.
Lambert
