PLL calculation on SPC5742PK1MLQ8.
I already downloaded the document from freescale site.
I want detailed information on PLL. How PLL locking mechanism is done? PLL error details.
PLL Register details?
Thanks & Regards,
Manju
From Subject Received Size Categories Praveen Ram Kumar RE: Enquiry on Freescale MPC5XXX safe assure platform 09:50 82 KB
Which document do you have on your mind? Have you seen following calculator?
Excel MPC5744P Clock Configurator
Excel sheet above generates code that is needed to use for proper PLL initialization. Does it answer your question?
