In MPC5746C micro, can any one hlep me to identify which PSR register is assigned to which peripherals.It's hard to find in reference manual.
Kishore.
Hi Kishore,
look at the reference manual, table 21-1. There you find Vector number, Vector offset and also Source module and Source description. This is only information, which is available.
If you use S32 Design Studio, there is intc_SW_mode_isr_vectors file. There are also comments to each interrupt vector.
Martin
