Hi!
I was wondering if the DS-5 Debugger from ARM is capable of debugging at the application level such as QT/QML on ARM iMX6 Sabre SD.
We develop QT/QML applications for iMX6 platform and sometimes we feel that the debugging process will be much faster using a trace tool or something similar. My doubt is if the QT Creator gives support to this kind of hardware debugging tool or other that I didn't mentioned.
Thanks.
Solved! Go to Solution.
Hi Daniel
seems GDB is native debugger according to
http://doc.qt.io/qtcreator/creator-debugging.html
http://doc.qt.io/qtcreator/creator-debugger-engines.html
also one can look at time storm plugins described on p.32
http://www.nxp.com/files/training/doc/dwf/DWF13_AMF_IND_T0847.pdf
Hi Daniel
