Hello.
I have a project created with CodeWarrior 10.5. When I open it with KDS 3.2.0, displays the error 'Program "make" not found in PATH'. It is a Kinetis MK60DN512 project in MQX 3.7.
Can anybody help me?.
Thank you
Hello Fernamdo,
Does this can help you ? Importing MCU V10.6 projects (sample, using PE and MQX) under KDS
and this : I am attempting to port a project from CodeWarrior 10 to KDS 3.0.
If this still can not help you , in my opinion, i recommend you create one new project on KDS, then
copy the files into the project , for sometimes , the porting are tedious work , there will be some error .
Hope it helps
Alice
