How do i upgrade Node lock licences to floating licences ?
nicolasdalstein
Is it possible to upgrade Node lock permanent licences to permanent floating licence directly from the NXP site ?
Where can I find the rate for such a transfert, if there is any ?
thank you
TICS_Fiona
Hello Nicolas
Yes, user can switch his node-locked CodeWarrior license to floating one. But this cannot be implement by user himself online, to do that I recommend you to log this request in Case system.
For details please refer to the post:
How to log an issue in Case system instead CRM (Service request - not used anymore)?
Best Regards
Fiona Kuang
Technical Information & Commercial Support
