How to know, from the list of ordered licences, which USB dongle is associated to which Ordered licence ?
已解决
跳至解决方案
2,577 次查看
nicolasdalstein
In the support part, I am able to see the list of licences I purchased.
It seems that I am able to generate a new licence file, but in order to do that I have to give an USB dongle ID.
Ok no problem until here.
My question is how to now which dongle is associated to which licence from the web interface ?
Thank you for your answers
标签 (1)
标记 (1)
1 解答
2,350 次查看
TICS_Fiona
Hello Nicolas
To get to know which license or which CodeWarrior suite that is locked to this dongle, you can search the ID from License Lists,  please see the screenshot as below:
Best Regards
Fiona Kuang
Technical Information & Commercial Support
在原帖中查看解决方案
4 回复数
2,350 次查看
nicolasdalstein
thanks for answer, but I could not make it work.
I raised a new case for that problem : case 00071825
Best Regards
2,350 次查看
TICS_Fiona
Hello Nicolas
I replied you in the case 00071825. Don’t hesitate to reply us for any further question.
Best Regards
Fiona Kuang
2,350 次查看
trytohelp
Nicolas,
The info provided by Fiona is true for all license files generated via the new web license system.
This was launched in December 2014.
Unfortunately for all license files generated before this date, you will not find them under your account.
Only the registrations were imported in the new system.
The information can be found in the old license data base only.
In all case giving private license details it's better under Case process.
Pascal
NXP Technical Support
2,351 次查看
TICS_Fiona
Hello Nicolas
Best Regards
Fiona Kuang
