Hello Martin,
MQX contains a DCU4 driver for Vybrid devices, you can find more information about this driver in the MQX_IO_User_Guide (chapter 34)
In addition you can find a dcu4 example code, this example shows the use of the DCU driver functionality on multiple layers: display, event handling, timing update, and alpha blending.
This example is located at the path: C:\Freescale\Freescale_MQX_4_2\mqx\examples\dcu4
Sol
Thank for information, but I had in mind some Windows graphic creators which do C source for MQX in vybrid supporting dcu4.
Perhaps PEG but I don't know whether support vybride and dcu4.
Thank for next tips.
Martin
