As KL46 only has a segment lcd interface, and the project needs a 6 RGB JDI LCD。 Is there a way to use segment lcd interface to drive a 6 RGB LCD? Thanks a lot.
http://www.j-display.com/product/pdf/LPM012A154A_v1.pdf
Solved! Go to Solution.
Hi Vincent,
After have a brief look through the reference manual of the RGB LCD, I don't think the SLCD driver can be available to drive this LCD.
And I'd like to suggest that you can select a MCU that contains LCDC controller, you can learn the kind of MCU in Kinetis series by this link as below.
K70_120 |Kinetis K70 120/150 MHz MCUs|Freescale
Ping
Hi Vincent,
Ping
