i've seen two types of configurations for my project - RAM & FLASH.
I want to know
**What are the signifies?
*Which one if to be used & for what purpose?
Solved! Go to Solution.
You can find some information to the link:
RAM Target with Kinetis Design Studio and FRDM-K64F | MCU on Eclipse
RAM is using RAM memory whereas the FLASH is using FLASH memory too.
You can see the lcf file used is not the same.
Pascal
Freescale Technical Support
Pascal
